Hi All!
I just scavenged a TV from the rubbish. People sometimes throw out perfectly good things but this find doesn't fit the category. After trying to change the cable fuse and checking the internal one I proceeded to a visual inspection of the power board and found two burnt resistors. The are connected in parallel and both connect the drain of two voltage regulators (and the anode of a diode) to ground.
- I want to change these two resistors but I am also wondering why this happened and how I can prevent it from happening again. The main fuse did not burn which would be surprising in case of a surge.
- Also, when looking for replacement parts I have found quite different looking resistors and I am wondering if the value and the wattage are the only things that matter or if the technology (say wire wound vs. silicon) is also important.
Thank you for your brain energy
The crime scene:
The schematic:
And for indexation in case anyone is looking for this schematic it is the power board for a LG 42LD450
The crime scene:
The schematic:
