Hey guys,
I built a circuit using a timer IC (TPL5111) connected up to the SHDN pin of a voltage regulator (MAX1724).
Here is a simplified schematic of the intended use of the timer IC:
The basic idea is that the device powers up, a microcontroller can do a few things, the microcontroller can indicate to the timer that its done doing whatever it wanted to do, and the device powers down for a few minutes with very little quiscent current drain... greatly increasing battery life.
I verified that the SHDN pin (EN pin) is held low for the duration of the timer, at which point its brought up to 3.3V to power everything up. The microcontroller does the task, then indicates to the timer that its done, at which point the SHDN pin is taken back to 0 volts again for the duration..... then repeat. This is good and is how its supposed to work.
My problem is that I can see the power rail gets 3.3V when powered up, but when powered down its held at a steady 2.8 volts. I can see that during this period of time current draw is still 4mA. It should be 0.0002mA when powered down (quiescent current of the voltage regulator in shutdown mode, and quiescent current of the timer IC).
Do you know what might be causing this behavior? Or how I should go about troubleshooting it? Any help/advice is greatly appreciated!
Here is my actual schematic for reference:
