AlanBown
Silvek said:Hi
Please can somebody tell me the easiest way to control the voltage output of
induction generator.
The generator is three phase 11 kW, excitet by capacitor bank of 240 µF; as
a prime mover a tractor of 30 HP has been used. The speed of the generator
can manually be adjusted, but when done, then the speed is more or less
constant.
The problem is that the output voltage depends greatly on the induction
generator speed and load. For a given capacitor value, self-excitation can
only be achieved and maintained under certain load and speed combinations.
The machine demagnetizes and stops generating either when the speed falls
bellow, or the load rises beyond certain values.
Your description above indicates to me that your looking for something that
can not be easily done. Every generator control I have ever dealt with has
the ability to increase speed as the load increases. Since your doing this
manually I see problems. Have you considered the frequency issue as well?
As load increases and the speed stays the same voltage and frequency would
fall.
http://www.flightsystems.com/electronic_generator_controls/
http://www.controlsinc.com/controls.asp
I hope these pages from google help your process
