Can anyone help me with building a small negative voltage power supply using a Max232 IC. The data sheet looks like it should be fairly simple. This would be to power the neg input of a LM741 Op Amp.
The MAX232 is an RS-232 communication chip, why not try a MAX680 or MAX681 or an ICL7660, there should be schematics on how to do this on their datasheets.
From what I see, the Max232 can output -5 volt and -10 volt by using some capacitors as a charge pump.... the two chips you referenced seem to output +5volt and +10volt...not what I'm looking for..
thanks
