i want to build an audio crossover and by the small amount of reading that i've done online, the most desirable crossover topology is the 4th order Linkwitz-Riley. linear gain in wide ranges, better Q, responsiveness, so forth...
so i found this 4th order LR crossover online http://sound.westhost.com/project09.htm. i'm building the one that separates the signal to 3 passes (hi/mid/low).
(i'm thinking of further filtering the mid in the future, but that'll have to wait until the whole speaker system is finished.)
anyways, there are a few things that are not clear to me. the author, mentions that the passes may be a bit of out-of-phase, BUT it's very small, etc... but then i saw that he also provided a small buffer circuit for each signal. so i was wondering:
1.) can the same buffer circuit can be used to insert a delay in each signal line, so they can be adjusted to be completely in phase with each other (or maybe i'm just getting the concepts from digital circuits mixed-up). i'm no electronics engineer. if not, is there any cheap buffer design out there that might do??
i know that i would be needing an oscilloscope for this (which i don't have, but i'll be putting one together in the coming months). but for the mean time, i might have to do it by ear... or maybe the close tolerances of the parts that i would purchasing online would be good enough that won't be able to hear it in any case.
2.) what are the best cut-off frequencies for high-pass, band-pass, low-pass to drive speakers. i think it might also be a matter of the quality and make of the speakers. so just give me the general values (20-500Hz/500-5000Hz/5000-20000Hz)??
