Building a pulse counter and generator
Hi All
I want to share this project with all of you. I intend to build a pulse counter to be use in a pulse genrator for my workshop. I will use TTL chips mostly with some CMOS exceptions. For the display I want to use some Soviet IV-8 fluorescent 7 segment tubes.In fact, are valves, with filament, grid and seven fluorescent anodes. I think they could be used as triodes. I;ve been trying them on the breadboard. I will share the designs that I have done in the coming days. I have attached a couple of pictures and there is a video on Facebook, that you can also see.
This will be a lengthy project as Mr Time is implacable with me and give me almost no chance for fun. Hope not to bore you with this project.
These are some of the circuits that I intend to use on the pulse counter. One of them has Spanish markings. If needed, I can translate.
  • Display ENG.pdf
  • Contador_de_pulsos_TTL reduc.pdf
bertus
Hello,
The video can not be seen.
There is a permission issue.
I do not have and want to have facebook.
I have attached a PDF that will let you understand chip interfacing.
TTL and CMOS do have different levels.
Bertus
  • Chapter 5 IC Specifications and Simple Interfacing .pdf
