Hi All,
I am trying to build a solar charger that can power my laptop (19VD.C, 3.42A, 65W). I have started looking at components and idea's but I am stuck at a few points and need some help. The plan so far is to buy a 80w solar panel, 12v 7ah battery, 5A charge controller, DC-DC converter to take the voltage from 12vDC to 19VDC and then straight into my laptop.
The problem I'm having is deciding if this will actually work (I do not want to buy the components to later find out that it's not suitable). Is this the best option to use these components or can someone recommend anything better? This is the first time I have ever studied or built anything like this so please go easy on me.
Key points:
Its has to be portable.
It has to power my laptop.
It has to be as cheap as possible.
Go easy on me as I'm here for help not a hard time.
If you have any further questions for me I will try and answer them all.
Thanks in advance.
Key points:
Thanks in advance.
