Andrew Wagstaff
Hi
I'm looking at building a linear power supply. I'm thinking of using a
12V 300VA torodial and linear regulators. I really want a power supply
that can be used to power both AT and ATX computer motherboards, has got
variable current limiting (3.3V, 5V and 12V) and displays current. I
haven't seen anything in the marketplace, so I was looking at building
my own.
The voltage and current ratings I'm looking at currently are:
3.3V 10A, thinking a 5A variable reg and using a pass transistor to get
up to 10A.
5V 5A-8A, thinking a 5A variable reg and a pass transistor.
12V 5A, thinking a 5A variable reg.
The voltage drop from 12VAC (~17VDC using a bridge rectifier) down to
the lower regulators (3.3V and 5V) was concerning me, as I was looking
at producing around 60W-100W of heat just for the 5V reg.
Was also considering having 4.5V, 6V and 9V. Was going to use another
variable reg - only need around 1A and using a switch to change between
them.
Another problem is how do I get the -ve voltages for the 5V and 12V
(only need ~500mA), do I just use some sort of polarity inverter or do I
need a centre tapped transformer?
I already have most of the components (except the torodial), that's why
I was thinking of going with linear. I do have some components to make a
5V switchmode, but I wanted to keep the power supply as quiet as I could.
Andrew
my own.
up to 10A.
them.
Andrew
