Hello,
I posted this in another forum, but this one seems more applicable in retrospect. have a Brother MFC-7820N multi-function printer/fax/copier that has stopped working. The LCD backlight comes on, but nothing else (display is totally blank). It does not sound like it is warming up at all. This machine stayed powered on all the time, and as far as I know, there was no material incident that triggered this. Just one day it would no longer print or respond to any keypad entries.
I removed the power supply board and examined it, and found a burned looking area around component D120 (per the attached pictures), which appears to be a diode (next to capacitor C101). I'm guessing that diode is my problem, unless others have better ideas? Does anyone have a schematic or parts list for this board, or are you able to identify this component for me?
I did a little looking around online, and it seems that PCPS0826 power supply board is the same as P/N: MPW5811, which should work for the mfc-7820N printer, mfc-420, and dcp-7020. So if anyone has info for any of these models, I guess it should be applicable as well?
Thanks for any help!
