Brightness control for HDSP 2133 dot matrix displays
I need technical help regarding the Brightness control for these displays . I don't want to use internal brightness levels (8 levels) that is its built in feature.
I want to change the brightness levels using 10 KOhm Variable Resistor with PWM (Pulse width Modulation) technique to have a smooth effect of brightness changing levels.
I am not interested in Night Vision circuitry that is recommended circuit of PWM for Night vision applicability by Avago Technologies and is written in Application Note 1039.
I need intensity control for HDSP 2133 Alpha numeric dot matrix displays so that it can change Brightness levels 0% to 100% smoothly with sunlight readability. Earlier I tried with PWM (modified night vision circuit recommend by application note 1039 by avago technology) but couldnot 100% duty cycle.
The attached circuit highlighted in red is the one that I have modified for sunlight readiblity
May be some one can guide me some good techniques to do so.
Your urgent technical solution will highly be appreciated.
