Sir Dzamija . . . . . .
Mine cost 10 to 30 times the price of yours, and guess what . . . .they are doing the SAME THING !
They just
RUN HOT, so expect some degree of metal discoloration near the area that the heating element is under.
To keep mine looking as nice as possible and to keep that oxidized area in control, I use a
brass wire grill brush to knock most of the oxidized area down, to where it looks decent again.
Seems like that is required about every 5 uses, and I put it away cleaned.
Only time will tell, on the long time life of your units internal heating element.
I will tell you one thing , those L o o o o ng tips that the iron comes with, loose heat RAPIDLY out towards the end of the tip.
I cut off the tips other ends blunt end, inside of the heating element tube, to then to make the outer tip length unit about 1/2 to 1/3 shorter.
If I need to reshape a tips end, I chuck the tips blunt end into a drill motor and then place it in my lap and use it "lathe" style to then take a mill file and slope file and dress up the outer tips point to a conical shape again..
I then place a small 45-60 degree slope on the very end 2--3 mm of the tip.
Then I tin it VERY-VERY-VERY well.
When I wear out a tip down to the no longer usable length I buy a BRASS 1/4 inch ( you will have
to convert that to mm) machine screw of 4 inches length and do the same tip shaping after you
figure the length needed to initially cut it off to.
The BRASS conducts heat well and the MAIN thing is, with those spaced out threading ringlets, you will never have to worry about an oxidizing and a hard SEIZING of a tip within the barrel of the heating element . . . . . thereby leaving you with a non fixable.
(This mainly pertains to my $ 60-80 Ungars, Wellers, American Beautys, etc )
ADD ON :
I just now remembered my favorite .. . . .the turquoise handled . . .60 watt Hexacons.
I ran it through a series configured triac controller for establishing its max temp setting . . .PLUS . . .a series inserted 1N4007 .
The clamshell iron holder, closed upon the weight of the iron being placed in it. That iron removal action engaged a micro switch so that the diode was shorted across and it's voltage reduction was then negated.
If I happened to be doing repetitive soldering actions, I used a second coil spring holder, mounted just above the primary holder, for resting the iron. At the end, of sequential uses, the main holder
was used
The idling / standby iron temperature just happened to fall, such that the tip was just BARELY able to melt solder.
So o o o it took minimal initial wait time to get up to normal solder operational temperature.
BOY. . . .did I ever have long tip life's, since that changeover.
In prior times, it was just burned out tip time, should I forget and leave the iron on for ma a a a any
hours . . . . .or . . . .shudder . . . .OVERNIGHT!
Thaaaaasit . . . . .
73's de Edd
