N_Cook
All LED flash on &off then latches up with the seven segment display
showing the decimal point only. Removed the single board from chassis
No stuck sw, no bad solder joints seen, no bad ESR caps. One time only,
pressing on area of pins 1 to 20 of 144 pin Boss chip the board started
responding to switch pushes, not repeatable since. Any special incantation
known ?
known ?
