Hey Guys,
Stumbled upon this site while researching my issue and thought I would ask a question.
So I bought a Boss DS-1 Pedal on ebay with the hopes of modifying it, called the Keeley Mod, and reselling it. I knew it was not working properly from the start but figured it for an easy fix. However, I have run into a problem. If I turn the distortion to about halfway or less, I get a low sounding, low volume farty popping sound. Turning up the distortion allows the guitar to be heard. I did find that C23 was swollen and had almost blown the bottom out so I replaced it. Unfortunately, the issue remains. As part of the mod, I replaced/upgraded a dozen or more components and added in a switch. These were mostly caps, an led or two, and a couple of resistors. I was wondering if it could be one of the transistors and if anyone new a good way to find their equivalents, since only the 2sk30a seems available anywhere. I think I can use it to replace Q6, Q7, and Q8 if needed. But I am unsure about the rest.
These components have all been replaced as part of the mod or just my snoopiing around:
C1, C2, C3, C5, C7, C8, C9, C11, C12, C13, C14, C18, C19, C23, R14, R35, D1, D4, and D5.
Here is the schem:
Here is the schem:
