Jon said:
But with a motor the cap will not be pulled to ground or even close.
My confusion is actually how it accomplishes. In the pdf link it has a
diagram of a basic driver. It shows a level shifter and some logic then an
omp amp.
My guess it that it has some logic to level shift the signal to whatever
floating hi and low it uses. The op amp is for drive capabilities. The op
amp is floating as the cap supplies power to it. Essentially as Rich as
mentioned it is similar to a voltage doubler. The cap is charged on the low
side then "lifted" to the high side giving effectively 2Vcc from ground but
puts Vcc across the op amp to power it and drive the high side gate.
If a load is between the high side source and low side drain then the cap
will not be charged up properly.
I imagine I could create some additional circuitry to charge the cap up on
the low side. Basically disconnect the cap and connect it to ground during
the low side. This is so that the cap can be charged during the load side
but is separate from the load. Of course this creates more problems than
it's worth.
For what its worth..
I see the circuit as a simple method of supplying the HS line, which
is the Vee of the driver of the high side, a "common" point as long as
the charge in the cap sustains..
When the low side output is on, this will then provide the "COMMON"
point for the HS line and also the cap how ever, the high side isn't on
at this time so the only thing that takes place is the recharging of the
cap.
The diode is there only to prevent back drain of this cap and supply
voltage for charging.
For larger caps with slower switching times, an external larger
diode should be used to relieve the strain from the internal one, which
could actually short it. This is something you do not want because it
will then most likely take out the high side output due to insufficient
drive at the gate which will put it into linear state.
These types of drivers are only good for PWM system or some kind of
pulsed system.. Most of the time, at idle, you keep the low side on to
keep the cap charged. I guess the ideal thing would be to run it into an
inductive load or have a inductor in series and have the circuit
generate a very narrow PWM to maintain the cap. With the inductor in
line, you shouldn't see much DC at the other end.
If you were to combine two of these for a full bridge, you'd keep both
low side outputs on at idle. Using the load isn't going to help much
here since it may be reactive or a some what higher level of R>
That's my take of it for what its worth!..
