the wheel that’s meant to rotate the cassette tape doesn’t work.
On the Kangaroo tape unit, is it being powered from the main boom box or are you using 4 internal cells ?
If the latter, do the radio(s) work O.K. ? Thus verifying no corroded battery connectors contacts .
I think that this player has
ALL of the bells and whistles . . . a
DELUXE unit.
Check out this unit and see if you have MORE or less of a unit than this featured Panasonic . . . or might they be the same.
https://www.petervis.com/electronics guides/panasonic rx-1950/Panasonic RX-1950 Cassette Compartment.html
https://www.petervis.com/electronics guides/panasonic rx-1950/panasonic-rx-1950-cassette-compartment/panasonic-rx-1950-cassette-compartment.jpg
There is one person . . . .Pharaon that lives afar . . . . .in the land of Oooomm-papa dow . . . . that might help us on the deck nuances /or/ comparisons , as we repaired his radio portion back in . . . .
https://www.electronicspoint.com/fo...ional-panasonic-stereo-model-rx-f80-2.277244/
Considering the radios working and power getting to the cassette portion.
Insert a tape and try fast forward and watch
BOTH the left feed reel and the right take up reel and the tape counter to see if
ANY movements from any of them ?
Same procedure in fast reverse and its observations.
Then place in play position to see if any reel movements and the additional front center BLACK pinch roller and the capstan drive shaft that it presses into should be turning slowly.
I am seeing only one ~1.2 mm square drive belt from motor shaft to the capstan flywheel, and then only geared friction clutches, are used for the feed and take up reels, so a broken or saggy drive belt would kill all tape transport action. ( ? ? ? You lucky dawg ! )
Th a a a a ssit . . . . .
Standing by . . . . .
73's de Edd . . . . .
Our cats regard us as warm-blooded furniture.
