You'll have to look up the exact part number and then the current requirements in the datasheet of that part.
The label you show gives no indication of power requirements.
Or use an AC transformer that can supply e.g. 5 A, connect it to the solenoid and measure the current the solenoid draws. This will give you an indication of the power required to operate the solenoid. You can then chose a matching transformer.
