Richard Henry
Does anyone have a pointer to a good technical discussion of the
Dreamliner batteries?
Follow articles in Aviation Week, The Wall Street Journal, and The New
York Times. Eventually there will be a comprehensive report from the
FAA and/or the NTSB.
The article in WSJ this morning said that the cause was traced to a
battery cell shorting itself. Why the cell shorted is not yet known,
but my guess is that vibration and bumps on landing are involved, mainly
because most test labs do not fly, so flying is what's new. Another
possibility is voltage spikes on the power busses due to the normal
operation of something else in the airplane (other than the charging
system).
Another article said that the FAA is pissed off at Boeing because their
safety analysis was clearly deficient.
Joe Gwinn
Jan Panteltje said:No but rumor goes the current plan is to do away with re chargeables,
and buy new Duracells before each flight:
Test labs do have vibe tables, though, and airplane designers do specify
vibe and shock standards for avionics. Everything is expected to not
only be designed for shock and vibe, but to be thoroughly tested.
Perhaps the difference is that they didn't shake things for 10 hours to
simulate a trans-Pacific flight. I dunno. But you can bet they were
specified, designed, and tested for vibe.
Again, this is a known phenomenon in avionics, and you design your boxes
to withstand such, then test the hell out of them before you ship. If
your customer is smart, they review your results, too.
The FAA tends to have a "blame the victim" mentality. If you go flying
and you crash because you did something, it's pilot error. If you go
flying and you crash because your equipment broke, then unless your
mechanic seriously pulled the wool over your eyes it's pilot error
because you took off with faulty equipment. If you go flying and you
crash because of bad weather, it's your fault because you didn't pay
attention to the weather. "Shit happens" is not a phrase to be found in
the FAA dictionary.
Obviously, if Boeing did a safety analysis that said the batteries were
OK, and they failed anyway, then ipso facto (by FAA logic) Boeing's
safety analysis was clearly deficient. Heaven knows -- the FAA may even
be right.
be right.
My theory/guess is that a cell shorted internally because of some
anomoly of operating at high altitude.
Joseph Gwinn wrote:
I think that every airline that paid $200 - 250 million each is also pissed
at Boeing, and will be exercising their rights under their contract to
collect damages for their grounded planes.
Jon
system).
Joe Gwinn
that's probably a good thing, their job it to find reasons for
accidents
and try to prevent them from happening again
remember one of the investigators on "air crash investigations"
saying
"pilots get too much of the glory and but also too much of the
responsibility"
clearly something went wrong, Boeing estimated less than one event
per 10million flight hours, now they've had two in fewer than 100,000
But better is an airplane that is stable all by itself,
and you can land as a glider... when no power.
The only hope now is on China, they are designing their own airplanes,
and soon you will be able to buy those on ebay for a fraction of the price of a dreamplane.
Probably nuclear powered electric engines...
Didn't the US government loan them (taxpayer) money to buy the planes in the first place? They'll just put an interest free moratorium on the payment schedule.
Didn't know that. Where did you see that ? Of course none of the
news or EE sites I saw said anything about that. Yuasa's been making
batteries for quite a while. I would think they would be one of
the best for this. Two installs and possibly two internally shorted
batteries and BMS is supposedly been weeded out as a problem.
They've also got the tanker boondoggle to tide them over. $52bn is a
considerably subsidy.
Best regards,
Spehro Pefhany
"it's the network..." "The Journey is the reward"
[email protected] Info for manufacturers: http://www.trexon.com
Embedded software/hardware/analog Info for designers: http://www.speff.com
On Saturday, February 9, 2013 8:21:49 AM UTC-5, MrTallyman wrote:
<snip rant>
This "MrTallyman" sounds an awful lot like that KRW troll ...
The problem is that it's still too soon for much else.
I don't buy that the problem is because Boeing wanted to cut corners on
the tests. Having a public problem like this costs many times more than
the entire battery system costs, and the battery system is a trivial
fraction of the cost of the airplane.
Something was simply missed while pioneering use of big lithium
batteries on aircraft. Somehow, the test setup does not capture
something essential about actual operating conditions.
By the way, this battery is not as large as for an electric automobile.
Don't know, but there was a picture of a burned-out battery box with an
engineer inspecting it, so one can get the general scale from that
photo. The box didn't seem that large. The size and weight was also
published, but I don't recall where I saw it.
To use a TLJ line from MIB "Try it" -K
I think you are a goddamned idiot who has zero capacity to see the
bigger picture in anything.
Try landing a 100% full to capacity craft of ANY design sans power.
It ain't fun, and you better be the best fucking physicist/pilot there
is. And think on your feet real fast.
Go back to your Balsa wood, rubber band powered gliders, child.
