Sir DaFlea . . . . . . .
Here is an " in Englee " typical application note from Puny Sonic, on their series of SMPS power IC.
Note that it is configured to output a MUCH greater power level than is being needed and generated in your unit.
Your input line fuse is using but a mere 1 amp fuse .
Your ruptured electrolytic photo, did not expose its specifications marked side, but on this unit, the probable equivalent would be the CVCC marked unit, which is on the " HOT " AC line . . . left side of the power supply.
Should you have a breakdown of the semis within the MIP2Gxxx, that could direct a fierce voltage level through this cap directly to ground.
The large upper CIN main filter lives a long untaxed life, with it merely operating at the 50/60 cycle line input voltage and frequency level.
Any electrolytics used down in the MIP2Gxx support area have a strained life due to their having to operate at FAST switching speeds of 10s of thousands on up to 100s of thousands of cycles of operating frequencies.
They take one hell of a hammering from those full voltage transitions and are prone to failure after some years of use.
That is also being particularly true over on the " COLD " side of the circuitry on the right half winding of the central Switch Mode Transformer where you can see involved Cout and Cfil units.
" Typical " Circuit . . . . . as Excerpted from a PunySonic Application Note :
VISUAL TUTORIAL
( On the testing of the 4 diode sections, internal of the units Full Wave Bridge Rectifier unit.)
The particular casing outline on the unit used in your system, is exhibiting a variant, in the respect
of the A.C. voltage coming up the board is connecting into side by side terminals on the bridge.
The rectified D.C. output voltage then shows up as side by side +and - terminals, just above.
With proper polarity foil connections routing over to the large black Cin main supply reservoir capacitor.
73's de Edd
