blood pressure!
priyank
Hello guys,
Its my first message to the group!!
currently working on builiding Blood pressure monitor and currently
working on pressure sensning circuit.
I am using MPX2050GP pressure sensor to sense the blood pressure from
cuff wrapped around the arm. pressure sensor based on the pressure
applied to it gives an output in millil volts(around 8-10mVolts- based
on pressure). My task is to amplify that signal using AD622 amplifier.
I connected my milli volt output from pressure sensor and got it
directly into input of the amplifier. It sounds very simple but i am
facing few problems with it.
I set amplifier to amplify signal 100 times. When i check my output on
the scope it only shows some DC crap on the signal.I need a clean AC
signal whos AMPLITUDE would vary with change in pressure on the sensor.
Would appreciate ur suggestion and help. project is due in weeks time.
John Popelish
priyank said:
Hello guys,
Please define the frequency band of interest.
I am also interested in the concept of how this mechanism will find
blood pressure from the signals measured.
The versions I am familiar with, use a combination of a slowly
changing cuff pressure (and a low pass filtered measurement of that
cuff pressure), and an acoustic pickup that listens for the opening
and closing of an artery that is being collapsed by the cuff pressure
and forced open by blood pressure (mimicking what a human would do
with a cuff and stethoscope).
Chris
Hi, John. I'd guess he's trying something like the BP setup shown in
Motorola/Freescale AN-1571, "Digital Blood Pressure Meter"
http://www.freescale.com/files/sensors/doc/app_note/AN1571.pdf?srch=1
If he is, the OP has chosen unwisely in using the MPX2050 instead of
the MPX5050 shown in the app note. The -2050 has a 0-40mV differential
strain gage-type output (unbalanced, some output impedance), whereas
the -5050 has a built-in buffer/amplifier which gives an 0.2-4.7V
single voltage output for the same range. Sadly, it's likely none of
this would have been necesssary if he'd gone with the right part. And
amplification of this signal buried in the "DC crap" is going to be
much more difficult from farther away.
According to the appnote, the OP would be trying to find a buried
signal of approximately 1Hz which is around 120uV to 360uV in
amplitude.
Possibly the OP should be a little more forthcoming with what he's
doing, and also take the time to describe what he's doing as far as
filtering -- which is the technically significant part on the analog
end. If he were to post a schematic on a.s.b.e or do an ASCII sketch
here, that might be helpful, too.
Apart from suggesting that he looks like an excellent candidate for a
PHB, I'll refrain from editorial comment on the original post. Blood
pressure, you know. ;-)
Cheers
Chris
Rich Grise
Hello guys,
Hell of a time to finally get started on your homework.
Find a sensor that has a sane output range, and use it.
Good Luck!
Rich
priyank
Hey Guys, thanks a lot for ur reply!
John i am working on oscillometric technique were in the cuff pressure
is measured.for the first semester my lecturer wants me to capture
output from pressure sensor circuit to view the pulse
component(Systolic and diastolic points in BP). He wants me to use
DSPACE card to capture the pulse component from output from pressure
sensor!
Chris i used MPX 2050GP as UNi gave it to me for free, i agree with u
that output is max 40mv but i dont have any other option. I appreciate
ur suggestion and will try get hold of 5050.The filter i have designed
is a 1st order RC network low pass filter using 741 op amp. Havin
operationg frequency from DC to 50 hz. is that filter good enough
chris?or i should use 2nd order filters. I agree with u, i am finding
it difficult to get my AC signal. any suggestions for that?
"excellent candidate for a PHB". Sorrry guys i didnt quit understand
that. Did i post something which i shoudnt be posting on the forum?
Will await ur valued suggestion! Thanks once again guys!
cheers
priyank
Chris
sensor!
cheers
priyank
Hi, Priyank. I guess you've got a bit of a conundrum here. Sorry
about the brusque answer before -- some students just want others to do
their work for them (like future PHBs). Hearing your explanation, it
just seems you're stuck. My bad.
Believe it or not, some fossils read TXT as not even taking the time to
bother to express yourself clearly, with all that implies. Odd, but
true. I guess we'll both have to deal with it.
You are actually heading in the right direction if you' *have* to use a
-2050. You'll want to use an instrumentation amp to amplify your
0-40mV differential sensor output signal into a 0-4V signal. But I'm
not sure the AD622 is the best choice. You've got power-up
considerations, and having the possibility of a negative input voltage
present at the input to your card and the filter might mean problems
down the line, if they can't handle negative voltages. The thing is,
you probably don't need to get the output of your instrumentation amp
right down to zero, anyway (if someone's BP is zero, they've got more
important things to worry about, like dying). It might be better to
use a single supply instrumentation amp like the LT1789-1 rather than
the AD622. The output can go to within a few mV of GND with a single
supply if your card can't handle negative input voltages. Since the
LT1789-1 can handle an indefinite short circuit, all you have to do to
protect the uC and filter input is put a 4.7V zener across the output,
and you're good to go. Choose a resistor for appropriate gain, and
you'll have pretty much an exact duplicate of the other sensor. (Go to
the Linear.com site and download the data sheet. While you're there,
download AN-43, "Bridge Circuits". You'll be glad you did.)
The sensor uses a recommended 10V supply, so you could go with
3-conductor shielded wire to the cuff (+10V, GND, and the IA output
signal). Be sure to use good grounding practices, and ground the
shield. Noise is going to be the real issue in this little toy.
If you go with the AD622, you'll need an extra line for a -10V supply,
and you should place a reverse-biased shottky in parallel with the
zener if your card can't handle negative. Again, the IC is short
circuit protected. (Download AN-43 at Linear anyway).
Once you get past this point, you can pretty much follow the Freescale
appnote on the filter. Read AN-1571 carefully. The herbs, the spices
-- it's in there. They explain what they did, and also why the did it.
Throw an LM324A into the breach, and just use the filter in Fig. 1.
If your card can handle negative voltages, you don't have to worry
about the two biasing resistors for the Voffset -- just use GND and
your venerable LM741, if you must. Since the oscillations you're
looking for aren't that amplitude specific, you don't have to worry
about offset or temp drift on the filter section.
You'll have two card inputs, and you'll have to scan assiduously at the
filter/gain block input to get the small heartbeat oscillations you're
looking for. You may have to throw some maths in to your program to
get post-filtering to nail down the systolic and diastolic points.
Residual noise is the *big* problem here.
If your results are deficient or inconsistent, once you've bashed your
head on shielding, grounding and the inate orneriness of small signals,
you may want to look at additional filtering, particularly for
50Hz/60Hz line frequency noise (this misery may actually be the object
of this lesson). Look at the normalized graph of Fig. 2. You've got
enough gain, but you may have problems with getting a clear enough
signal (you should see something significant from the output of the
circuit in Fig. 1 when you use the BP cup and are between systolic and
diastolic points, or your sensor might be dead). The frequency of
interest is in a low enough and narrow enough bandwidth that there are
several things you can easily do. Feel free to post again for more
advice on filtering line frequency noise and improving power supply
rejection.
To give a better presentation, you might want to include a factory cal
routine to provide a reality check on the pressure measurement. Using
good components, it shouldn't be too difficult to get something that
will pretty much correspond to the drift specs of the sensor. I would
guess for class you're using a standard BP cup and teeing off the
manometer fitting, so you might just want to factory calibrate to 200mm
on the dial of the sphygmomanometer rather than using a tweaker pot to
get it right. The gain pot will ruin your precision and your drift
spec, anyway.
Kewl project. Have fun.
Chris
priyank
Hi Chris
I spent 5-6 hours trying to get the thing workiI am sorry to the forum
if you guys thought i was trying to get my homework done. Trust me that
was not the case. Its just that i am frustrated with this silly little
thing and i am not sure whats wrong with my circuit!
ng and get rid of noise and get clean signal!
I have now decided to chuck mpx2050gp out and get ASDX015D44R, its gona
cost me fortune but i wannt this thing working.
http://au.farnell.com/jsp/search2/browse.jsp?N=500001+401+1001501&No=50&Ns=PLS_SKU|0#results
http://www.farnell.com/datasheets/60901.pdf
Guys u wannt believe but in AUstralia i am not able to find mpx5050gp
and neither the amplier u suggested.
Dspace card does take in negative supply but then to I will surely get
rid of AD622 and get a single supply amplifier as per ur suggestion.
I have bought the LM324 as per the apllication notes and will get the
filter soldered on veroboard tonight.
WIth the filter i surely agree have lot of work needs to be done! I am
really confused about what filter would be best for my circuit!Ill
again go through the textbooks today
I have got the pictures of th output waveform which i am getting on the
scope(i am first trying to check circuit on oscilloscope) and ill try
post the link for pics within next 5 hours.(lol... it will atleast
prove im trying and not trying to get my homework done).
Chris i appreciate ur help and not even my best mates would have helped
me so much.
(sorry bout my spelling errors!)
cheers
priyank
Chris
priyank said:
Hi Chris
me so much.
cheers
priyank
Hi Chris
me so much.
cheers
priyank
Hi, Priyank. OK. I'm assuming you're in an electronics course of some
kind, but I might be wrong. If you wouldn't mind, could you mention
whether you're in a trade school or college, you are an electronics,
computer programming or biology major, what's this class, and what
level class this is.
Here's the deal. If you put something together on a board and plug it
in, it *always* works. If flames are erupting from your board, if
power is hooked up backwards, if you've got everything miswired, it's
still working -- it's still doing exactly what you made it do. You may
have wired it up wrong, you may have hooked up power backwards, but
it's just obeying the laws of physics and the way the chips and
components are designed.
If your circuit isn't doing what you want it to do, you might not
understand what it's made to do. You might not have followed the
correct procedure to get it to operate properly. You may not really
understand what you want. But the problem is you, not the silicon or
wire or metal film or electrolyte and foil, even if there's smoke
pouring from your breadboard. Especially if there's smoke pouring from
the breadboard.
You should be able to cobble together something that works fairly
quickly. You have the sensor and the ICs right now to make something
happen now. An AD622 is a great IC -- it just happens to need dual
power supplies, which might not even be a problem for you. Wire up
your AD622 with the gain set resistor on a small piece of perfboard,
and mount it right next to the sensor (less than an inch away). Now
the venerable LM741 is easily capable of doing the job of the LM324 on
the other side of the 4-conductor wire (near your DAC board) if you
have dual power supplies. Look here:
| DAC Board
| Sensor Instr. | |
| Amplifier | |
|| 0-40mV | |Av = 1000 | | |
|| output | | | | |
|| | | o--o---------------o A |
|| o---o | | | |
|| o---o | | .---------. | |
|| | | | | | Filter/ | | |
|| | | | | |Amplifier| | |
|'--------' '----------' '--o o--o B |
(created by AACircuit v1.28.5 beta 02/06/05 www.tech-chat.de)
This is easy.
Your basic cut 'n' paste circuit can be logically divided into blocks.
Look at block 1. It's the sensor. It gives a 40mV differential output
for 0-50kPa. OK. Disconnect the outputs from everything else, power
it up, and then just put a DVM across the inputs while you apply some
air pressure. If you see a millivolt signal, at least you know it's
kind of working. If not, you may likely have smoked it, either now or
before. If these are school samples, they may have been donated from a
broker who had problems with them and decided to get a tax writeoff for
the lot -- it's conceivable you got the one bad one in the lot. No
output? Get another one.
OK. Now look at block 2, the IA. You've chosen a resistor for a gain
of 100 (0-40mV to 0-4V). Does it work? You can reconnect the sensor
if you want and apply that pressure again, or you can just ground one
input and apply a millivolt signal to the other (if you don't have
anything handy, a "D" battery, a series resistor and a pot will make a
good one). Apply a 30mV input. Do you get a 3V output? Does it do
what you think it should do? If not, feel/smell for a hot IC, recheck
your wiring, look at every conceivable way you could have messed it up
before you conclude the IC is bad. If it is, you probably smoked it
before. Get another one. Use your meter. Use your head.
Now look at the filter section. It blocks DC. It lets AC pass. If
you don't have a function generator or any other lab equipment, just
hook up a low voltage transformer, and use a series resistor and a pot
to apply a 60Hz signal of about 2mV at the input of the filter. If you
wired it up right, you should see a large amplitude 60Hz signal at the
output. If you look at the app note, it says the Fig. 1 filter is
amplifying the millivolt signal up to tenths of a volt, so you should
see some good gain here.
Once you've gotten to this point, disconnect the sensor again, and
ground one side of the IA. Apply a 30mV DC voltage with a 1/4mA AC
signal riding on it (battery, transformer, series resistors will do
fine -- just apply your basic DC circuit theory you must have had
sometime before you got into this class). Look at the output of the IA
and the output of the filter amplifier. Do they work together?
This is a basic reality check on your stuff -- is it smoked, or does it
work. If I had your circuit on a board in the lab, I'd do this first.
With decent lab equipment, it wouldn't take more than a few minutes to
find all this out.
You've gotta walk that long road alone. And you've gotta use the tools
you have, including your head.
Git R Done
Chris
Stef Mientki
go to a hospital,
cardiology or some bloodvessel department,
ask for a dispossable pressure sensor,
in quantities they cost about 5 to 10$,
and they just are as good as the farnell stuff.
Stef
priyank
Hello Guys,
Forwarding link to pics which shows the output im getting from filter
onto scope( showed GREEN picture output to my proffesor and he is not
happy with output and wannts output similar to application notes).
regarding filter have decided to try one in the application notes.
I just have seven days to go, any more suggestion?
Once again thanks for ur support guys! I will surely have few sleepless
nights ahead.
Link
http://pg.photos.yahoo.com/ph/priyank_samani2002/album?.dir=/32b7scd&.src=ph&.tok=phAma6EBHruDcuMQ
cheers
priyank
Chris
the breadboard.
| DAC Board
| Sensor Instr. | |
| Amplifier | |
|| output | | | | |
|| o---o | | | |
|| | | | | | Filter/ | | |
|| | | | | |Amplifier| | |
This is easy.
find all this out.
Git R Done
Chris
OK, Priyank. If you're saying you've got a week left, you don't have
time to play. Don't buy anything yet if you've got split supplies and
your DAQ board can handle negative voltage inputs. You don't have time
to wait for parts. Change over to the filter/amplification block shown
in the Freescale appnote, using your venerable 741. Put it all
together, as shown in the block diagram above. Place the AD622 right
next to the sensor. (By the way, use a couple of good high frequency
tantalums to bypass the AD622 power supply at the IC, otherwise you're
going to have noise problems big time.) Run through the above
preliminary checks to make sure the blocks are working in a gross
fashion, as shown above. Replace anything you smoked before. Get it
all to the point that you're ready to start.
Now that you've done that (shouldn't take more than an hour or two if
you've got access to split +/-10V supplies, but +/-12V or even a +/-15V
supply will work for your sensor, Freescale says +16V is abs. max.),
it's time to actually start working. Start by putting the BP cup on
your arm, closing the valve, pumping it up to over 200, and then
cracking open the valve so it will slowly decompress (should take about
30 seconds or so). Just feel what's happening with your arm as it
decompresses.
You should be able to feel the pressure of your blood pushing slightly
against the BP cup as it decompresses. The BP cup tries to compress
your arteries. As your heart pumps blood through your arm arteries,
they push back, trying to expand to accomodate the flow of blood. If
the BP cup is pressing too much, there isn't enough blood pressure
being generated by the heart muscle to open the arteries even at
maximum pressure. If the BP cup is pressing too little, there isn't
enough pressure to close the arteries at all, even inbetween beats.
That maximum point (the point where the artery is too compressed to
allow blood flow at all) is called the systolic pressure. The minimum
point (where the pressure is too small to cause constriction at all) is
called the diastolic point. Between those two points, the vessel is
pushing open during the high pressure points in the heartbeat cycle,
and closing in the lower pressure parts. This expansion and
contraction of your arm as blood is trying to flow is reflected in your
pressure sensor, although it's not a very reliable effect. It's a very
small effect (as shown in the appnote, about 1mm Hg to 3mm Hg, see
p.2). As Mr. Popelish noted above, this method isn't used in better
automatic sphygmomanometers, they'll use an audio pickup. It is useful
for the "free blood pressure" displays you see in local drugstores that
give our senior citizens something to obsess about while they're
waiting for their meds. And the "oscillometric method" is kind of
indestructible, although not extremely accurate.
But the effect *is* measurable. That's your job. If you want to do
this, you have to take responsibility for acquiring that signal, using
the sensor and the ICs and your DAQ board to do so. If they're working
properly, you do have the tools to do the job. If you have any lab
equipment (an oscilloscope would be nice, a DSO nicer, a function
generator would also be helpful) it will make the trip easier, but you
do have what you need. I could probably get it working with a cheapie
DMM, power supplies, and a transformer and handful of resistors and
caps, although I'd have a heck of a time troubleshooting or tweaking
it.
Again, the appnote filter alone will probably not be sufficient to do
the job well. You'll need either a programming algorithm or additional
filtering to get rid of power supply and line frequency noise.
Depending on the acquisition frequency of your board and your software
skillz, you may also want to add a peak detector to simplify the data
acquisition software to a minimum.
But you can work on that later. Get to the starting line first by
taking ownership of your project, really understanding what you need to
do, and putting together the tools you need to do the job.
Everything I've described here up to this point could easily be
prototyped by an engineering technician in an hour or two. It's not
that hard.
By the way, if you want more help, I need to know something about your
background to be able to answer usefully. Are you in a trade school or
university? What year are you? If university/college, is this the
senior project?
Git R Done
Chris
priyank
Hi guys,
Chris ur explaniation was really helpfull and inspirational. I followed
the steps u told me.
1stly started with the amplifier. Got a signal from Func. Generator and
supplied 100mv-pk pk signal to amplifer @ frequency range from 1 khz-
1HZ. Amplifer works perfectly. Only thing was at frquency below 50 HZ
output signal on the scope was flickering.
Further tested the filter. With the filter again supplied the same 100
mx-pk pk signal. The pin config in application notes is wrong. Pin 11
needs to be grounded and supply should be at pin 4. At 1khz signal i
had no luck. WHen i went down to freqauency below 100 hz, output
amplitude increased and gain was around 100-150. Onlt issue was the
poutput i got was like triangular wave. If i pull out 330 microfarad
cap output turns to be a squarewave.
Further tried combination of AMp and Filter. Agan had no luck at 1 khz
input. When i decreased frequency below 100 HZ, ouput i got was like
combination of sinewave and the triangular wave. Gain was around 200.
For noise at input i have put 22 microfarad electrolytic cap. EVen my
professor said that noise is gonna be a big issue.
I will try varioud stuff to get rid of noise.
WIth teh sensor i coudnt get hold of the professor. Today i will get a
new one.
I have a feeling that something is wrong with my sensors. I belive that
output signal from sensor is not being transfered to the input of
amplifier properly. There is no rocket SCIENCE in this project. I am
making some minor mistake.
No matter the cost i am gonna get this thing working!
Sometimes words are not enough to convey the thoughts and feelings, but
thanks a lot chris.
i will keep u posted!
cheers
priyank
priyank
Hi guys,
new one.
thanks a lot chris.
cheers
priyank
Chris
priyank said:
Hi guys,
new one.
thanks a lot chris.
cheers
priyank
Hi, Priyank. I'd still like a bit of information on the class you're
in -- it's hard to give practical advice without knowing where you're
coming from. From the message string I'd guess you're enrolled at VU,
but I'm not clear if you're in a TAFE sequence, the standard EE
program, or a biomed undergrad.
Again, this isn't hard -- at least to get a start on things. You've
got a sensor and two ICs, one mounted in the pressure cuff (IA) and the
other mounted close to your DAQ board (filter/amplifier op amp).
You've got the standard IA configuration for a gain of 100, and you can
cut&paste the filter from Freescale AN-1571, Fig. 1 (V(offset) = GND if
you're using a split supply and an LM741)
The question of electrical noise is always a tough one. There are many
ways to work on this problem, which is central to a lot of biomed
applications. From the way I read your post, it sounds like you've
just hung a cap at the DAQ and filter/amp input -- I'd like to offer
the suggestion that having the instrumentation amp drive a cap directly
is just so wrong.
| | | UNWISE CHOICE! |
| | +10Vo--------------o--------------------------o +10V
| | | o------.
| | Vo+o---o------' | ---
| | | | |10uF --- |
| | | | | '-|-\ AD | |
| | | .-. | | \ 622 |
| | | | | '---o \ | |
| | | | | | >---)--------------o----o Vin
| | | '-' '---o / | | | To DAQ and
| | | | | | /| | +|22uF Filter/Amp
| | | | | '--o-o--------------o-----o GND
| | Vo-o---o------' | |10uF |
| | | o----'
| | -10V o--------------o--------------------------o -10V
| Freescale 4 Conductor
| Pressure Shielded
| Sensor
Let's count the ways this setup is asking for problems. To start with,
while the AD622 is current limited and can handle an indefinite short
circuit, it's not made to directly drive a capacitive load. You're
almost guaranteed to have the IA oscillate like heck. It will also get
hot with the current spikes while it's oscillating, which is going to
degrade its performance pretty severely if it lives. Mercy on the poor
Analog Devices chip? Sadly, no.
Now the power supply current is going to be bypassed at the IA by two
tantalum caps. This, again, is a good thing. But you're also going to
have the power supply current variations impressed on the GND line
coming back to the DAQ board. If you're looking for a millivolt-level
signal, this is a prescription for problems. Having the bypass caps
there will just tend to even out the spikes, and also lower their
frequencies, bringing them closer to your frequency of interest. This
becomes a bad thing. It gets worse when you start looking at the poles
in the feedback loop of your power supply ripple. This also increases
the noise, and the chances of oscillation.
If I were doing this, the first thing I'd say is that you have to
separate the power supply lines from the signal. That would mean a
separate 3-conductor for the split supply, and a two-conductor twisted
pair shielded for the signal. I would connect the two-conductor at the
IA itself (pin 6 +, pin 5 -), and have that go directly to the DAQ and
filter/amp board. At the filter board, I'd just use a load resistor at
the input, and use a diff amp to separate out the signal itself from
the noise generated by the power supply lines, having that output go to
the Fig. 1 filter.
This should at least be a start on getting where you want to go:
| | | WISER CHOICE |
| | | o------.
| | | | |10uF --- |
| | | .--. | |\| | .---->To DAQ
| | | | | '-|-\ AD | | |
| | | .-. | | \ 622 | |
| | | | | '---o \ | | | |
| | | | | | >---)-------------------------o---->+
| | | '-' '---o / | | | |
| | | | | | /o----)------------------. .-.To Diff Amp
| | | '--' .-|+/ | | | | | 2.2K| |then Filter
| | | | |/| | | 2-conductor | | |
| | | | | | | | Shielded | '-'
| | | | | | | | '------o---->-
| | | | | '--o-o-------------------o GND
| | | o----'
| Freescale 3 Conductor
| Pressure Cable
| Sensor
Note that the twisted pair negative wire should be connected as close
as possible to pin 5 of the AD622 IA. Of secondary importance would be
keeping the trace between pin 5 and the power supply GND as low
impedance as possible.
The diff amp prior to the filter will do the most to knock out noise
(any antenna pickup should be impressed equally on both lines, and will
be cancelled by the diff amp). The voltage drop caused by the 2.2K
resistor is a linear function of the current, and while it will tend to
attenuate the signal a little, it shouldnt affect the basic signal
fidelity.
In the "real world", of course, this circuit has the deficiency of
being pitifully unprotected from ESD and the other challenges of
putting electronics in the hands of people. Op amp inputs and outputs
floating in the breeze, indeed. But the main difference between this
circuit and anything you'd make for real would be the utterly essential
requirement of providing galvanic isolation between the patient and
your electronics. That changes a lot.
Just for yuks, a biomed engineer would probably be looking at something
like using a galvanically isolated DC-to-DC converter at the box end,
and then use a precision optoisolated V-F conversion to read the gross
pressure (DC level), and a linear isolation amplifier to cull the
millivolt signal from the DC level. Added expense and complexity --
you can see how doing this stuff in a medical environment can add
costs. Also, you would probably want a dedicated DSP to do
post-filtering on the oscillometric information, which makes this a
real project and a half. But if this were a free-standing box, the DSP
could also do the pump control, user interface and display, too --
there's not much to do while the conversion is taking place, and many
DSPs have ability to spare. And if that isn't enough, you'd have to
look at radiated emissions (stringent medical requirements to avoid
interfering with other kewl stuff).
Feel free to post again if you've got problems, but I'd guess that the
WISER CHOICE setup above (cost: 1 additional op amp for the diff amp,
and a second 2-conductor twisted pair shielded wire) should be pretty
much what the doctor ordered, at least for your classroom setting.
Good luck
Chris
Chris
is just so wrong.
| | | UNWISE CHOICE! |
| | | o------.
| | | | |10uF --- |
| | | | | '-|-\ AD | |
| | | .-. | | \ 622 |
| | | | | '---o \ | |
| | | o----'
| Pressure Shielded
| Sensor
the Fig. 1 filter.
| | | WISER CHOICE |
| | | o------.
| | | | |10uF --- |
| | | | | '-|-\ AD | | |
| | | .-. | | \ 622 | |
| | | | | '---o \ | | | |
| | | '-' '---o / | | | |
| | | | | | | | Shielded | '-'
| | | | | | | | '------o---->-
| | | o----'
| Pressure Cable
| Sensor
fidelity.
Good luck
Chris
I didn't mention that the easiest way to set up a diff amp is by using
an instrumentation amp. If you have a spare AD622, you might want to
do this (view in fixed font or M$ Notepad):
| DAQ input 1
| | (BP)
| +>-----o-----------. +10V |
| | Av=1| | '-|-\ AD |
| .-. .-. | | \ 622 | 0.33uF +10V
| 2.2K| | | | '---o \ | || |\|*
| | | | | | >-------o----||-o------|+\ DAQ input 2
| '-' '-' '---o / || | | >-----o-->
|2-cond. | | | | /| .-. .--|-/ |AC Osc
|shielded | '--' .-|+/ | 1Meg | | | |/|* |Signal
|twisted | | |/| | | | | -10V |
|pair | | | | '-' | ___ |
| ->-----o-----------' |=== | o----|___|--'
| |GND +2.5V | 150K
| -10V | |
| 1K| |
| * Bypass with tantalum 10uF16V to GND '-'
| 33uF---
| GND
Use an LM385BZ2.5 for the reference voltage (helps keep the 33uF cap
from being reverse-biased -- good tantalums will act funny when they've
got AC across them). Or cobble together a 2.5V reference from whatever
you have handy.
Now you literally have the whole thing. Cut & Paste this and WISER
CHOICE above to Notepad, assemble it, and watch it run. I'll bet your
noise issues will, at the least, be the best in the class. The
programming is up to you (or at least, get somebody to give you the
coding answers on another newsgroup).
Chris
priyank
HI chris,
I am enrolled in Victoria UNi, Melbourne in EE course!Majoring in
Telecom, Control and EHV power!
When it comes to software application(matlab, controldesk, CAD,
simview, programming -C++,java,VHDL ) i can beat any student in my
class.I must confess i am not good with handling of hardware. Specially
when it comes to the noise issue.
I hardly have any options left now--i surely do have spare AD622 and
will try ur suggestion.
I now feel i have taken a wrong project, should have taken a software
based project, Its basically a do or die situation now for me.
For strength and honour!
I will keep u posted!Have a winning day ahead!
cheers
priyank
Chris
priyank said:
HI chris,
cheers
priyank
Actually, Priyank, considering you're doing a biomed project, it's
"For DUTY and HUMANITY!"
-- Moe Howard, Larry Fine and Curly Howard, "Men in Black (1934)
Some hardware background is invaluable for a programmer.
Consider it like our Russian friends, who go into a steaming sauna,
switch themselves with birch branches, then run out into the snow and
jump in the frozen river.
"Comrade, why do you do such a crazy thing?"
"Because, comrade, it feels so good when it's over!"
Cheers
Chris
