Hello everyone !
I'm still working on my 8 to 1 home made SCART switch, and found I needed to use a relay for the "slow switch" signal, because it can go up to +12V, and the 4051 I use are limited to +6V input.
Anyway, I eventually found this page :
https://www.electroschematics.com/6546/low-current-relay/
I basically understood the circuit and how it works, however I wonder why this one uses 2 transistors ? Isn't it possible to make it work using only one PNP transistor, as we usually do with a capacitor charge / discharge circuit ?
One colleague of mine stated that the 2 transistors are here to limit the current increase speed when removing the power, to avoid a extremely high voltage at the ends of the relay coil, which may damage the capacitor and / or the semiconductors, but I don't understand how and why it would work.
Can someone show me the light on this ?
