colin
Im considering a direct drive for an actuator.
mainly to do away with backlash and anti backlash gears etc,
presumably there will be less noise too.
I worked out I need at least 30NM of torque,
wich is a lot more than most motors, (~x100)
but only about as much as a starter motor.
but it also has to effectivly lift its own weight at the end of the arm.
pancake motors seem to be quite efficient,
but i got stuck trying to work out the optimum format,
obviously diameter as large as posible wich can be 200mm
but how many steps is optimal ?
if the force on a wire is proportional to current and field strength,
how does the number of poles affect this presuming the total wire length
remains about the same ?
yet stepper motors seem to have more torque the more steps it has.
I did quite well at electric machines at uni,
but that was ages ago.
Il probably need several layers, ive got a collection of
neodinium magnets, wich im going to try play about with.
you can also get fairly large discs,
is it practical to remagnetise these ?
Colin =^.^=
Colin =^.^=
