Mr. Land
I picked up an as-is JVC receiver to play with on eBay recently. From
what I've read, this particular model is renowned for running
extremely hot. Removing the top cover revealed that this is actually
the case: the plastic outer sleeves of all four of the large power
supply filter caps have all shrunk, and one of the four caps actually
burst open at the top (spraying a lot of paper debris inside.)
This unit has 7 power amplifier circuits utilizing 14 power MOSFETS.
All of the output MOSFETs are mounted to one long, flat heatsink, with
one long flat clamp bar.
Since I've gone through the trouble of getting out the main board to
replace the caps and test related stuff in the power supply, I decided
to check all the output MOSFETs too.
The output MOSFETs were insulated from the heatsink by what I'm
guessing are rectangular sheets of silicone rubber, with groups of 4
devices sharing a single sheet, with the final 2 on a smaller sheet
(the JVC service manual calls them "RUBBER COOLERS", but let's not go
there.) When I removed the devices, the sheets pretty much
disintegrated (perhaps due to heat/age). Now I'll need to replace
them all.
Being an old-timer I'm used to using the thin mica insulators w/ the
white thermal compound. But this approach would be considerably less
thick than the original silicone sheets. Are the silicone sheets
superior or inferior to the mica/paste approach? (I vaguely remember
seeing a thread about this, but I couldn't seem to find it.)
I looked on my favorite parts sites (Digikey, Mouser, Newark) - none
seemed to have anything like these.
Should I try to get original parts, or...?
Thanks!
them all.
Thanks!
