I am a retired scientist doing photophysics experiments in a home lab. I can do the basic stuff required to customize instruments, program microcontrollers, and build digital circuits but lack the EE skills to design anything complicated. I want to build a one-off device that will allow me to pulse high-current LEDs (for example, those in the Luminus Devices Phlatlight-121 series). These LEDs operate at a few volts and are rated for continuous currents up to 30A. I want to create ~100 microsecond pulses at maximum current. I would like a reasonably square wave form. Pulse frequency does not have to be particularly high: 100 Hz would be okay. I am building my own strobe rather than buying one partly to save money but also because I want complete, software-level control over the pulse train.
I am wary of using a switching power supply because of concerns about power-quality and not knowing what will happen if I put a bunch of MOSFETs downstream from a device that is already full of transistors, inductors, capacitors, and feedback loops. Hence, my plan is to use an old-fashioned, heavy-duty linear power supply. For example, I have one that can produce 37A continuous/50A peak at 15 V, although the voltage-regulation range is narrow (11-15 V) so I will need to step-down the DC voltage if I use it.
Now to the question. I need to put something I can regulate with TTL output from a microcontroller between the power supply and the LED. I find the world of LED drivers bewildering. What kind of driver do I need for my application? Please be as specific as possible: companies like Mouser sell dozens of different ones with high current ratings, but none seems a natural fit for my project since they are mostly designed to implement complicated dimming schemes. Or, is there a better, relatively simple way to achieve my goal? Thanks in advance.
