Best cheap MCU for LED project
Hey Guys,
Just looking for some advice on the best MCU to use in a simple LED project.
The unit is powered by 3 x LR44 and with cycle through 4 modes.
Flashing RGB
Flashing RB
Flashing BG
Slow fading between RGB
and Press and hold to turn off.
Using a single 5mm RGB LED.
The main thing is price as we are going to make lots of these :)
Like 10000 units to start with.
So the price is a pretty large consideration. So thinking lowest cost for the functions required.
Any tips would be excellent.
Thanks heaps
Jason
I know only PIC microcontrollers, so I can give you info only about them, there may be others that are cheaper.
So you need 1 input and 3 outputs. A 6 pin PIC could do the job. Partly it depends on how good a programmer you are.
The PIC10F series are 6 pin PICS and range from $0.31 o $0.39 volume pricing.
I think I could cram the entire code into even the smallest one, PIC10F200 but it would be a challenge with 256 instructions and 16 bytes of RAM. The higher end ones have better instruction set and 512 instruction memory and 64 bytes of RAM. I am certain I could code it for that one.
If I were you, I would attempt to code it and see which one is needed.
Bob
Hey Bob,
Thanks for the quick reply. I think it's a good idea to write the software to see which size we need. Thanks for the good advice! :)
Jason
