Voltaic,
I don't know the history of your posts, or who suggested you should be banned, but I certainly did not see anything ban-worthy in this thread....worst-case, as hevans1944 stated, perhaps a bit naive, but as long as you are making an honest effort to learn I would urge you to continue....That being said, due diligence is an important part of the learning process regardless of venue....for instance, when I posted the Wikipedia link to NiChrome wire, you might have followed it and perhaps even scrolled down to the table that shows the relationship between wire diameter, Amperage and Temperature and noted something along the lines of: #30 NiChrome wire reaches 204C @ 0.875A.......538C @ 1.74A......meanwhile #20 wire reaches 204C @ 3.58A and 538C @ 7.25A .....You might have then scrolled down a bit further and noticed the resistance per linear unit of NiChome wire decreases rapidly with respect to an increase in cross-sectional area (read: diameter)....putting the two things together you might have thought to yourself, "Selecting the right diameter wire is critical to keeping the wire temperature below the melting point of plastics and the flash point of fabrics it might come in contact with"....instead you posted:
The nichrome wire sounds like a good option, I guess I can just glue it onto a board with some plastic on top or inbetween two layers of fabric or plastic.
Because it appeared to me you had utterly failed to grasp any of the salient properties of NiChrome wire I immediately began to worry about the potential safety of your experiments....It is completely possible to start a fire using NiChrome wire using even a very limited power source....if the plastic, fabric or glue used were volatile in the temperature range you might even have started a fire that proved difficult to extinguish....so I felt the need to steer you in a direction better suited to safe experimentation by someone who does not bother with due-diligence. In short, there were a myriad of ways you could have responded that might have led to actual help in designing a NiChrome wire based heater for a specific purpose, but they all would have required some effort on your part....because your response suggested you would very likely end up doing something potentially dangerous I was forced to suggest you steer away from starting down the path at all. That is unfortunate, but not, in my opinion, ban worthy in and of itself.
If you do decide to seek a forum where safety is not a primary concern, then I can honestly say, "I hope you don't find it." Regardless of where you go or what you do, I would urge you to spend your time making an effort to learn, a large percentage of forum responses to neophytes from "experts" are cryptic....a clue more than an answer...a test of sorts of the poster's willingness to seek out answers if given the right place to look....no one wants to spend their time and effort doing other people's work for them, but thankfully there are people who will help point out the right direction to learn so that you can do the work yourself. I cannot think of a single example in this forum of someone being castigated for making an effort to learn by asking for help, this is, after all, the stated purpose of the forum....but their are plenty of examples of people who expect the the forum to solve their problems and design their projects without any effort on their part....these people typically do not remain active or welcome very long. I have never been part of a forum where laziness and/or apathy were highly regarded; on the contrary, all of the forums I have participated in were created by people passionate about the forum subject and almost universally had a deep-seated desire to help others learn about the forum subject.....In none of these forums have I ever encountered experienced, knowledgeable people with a desire to help people who are unwilling to make an effort on their own......
Just for emphasis:
Good Luck!
Fish
