Spookgud
I have aircraft and first I use 7,2V 1800mA SANYO and standard motor and myJohn Doe said:I am impressed by the rapid improvement of NiMH batteries. I was told
that Lipoly batteries are better for radio controlled aircraft. After
doing a little research, I noticed they might be poorly designed and
hazardous in the sizes required. But I like the voltage. What about
using regular lithium batteries? The problem is still going to be
regulation, charging and discharging, isn't it? Comments about any
useful types are invited. Thank you.
fly time was around 15 to 20 minutes if I lucky. After I change to Litium
Polymer 11.6V and 2000mA and brushles my flyingtime was at most 48 minutes
and that when playing att ground not try go upp with some termike.
I think my storry tell everything.
But one warning it can start fire if you crach the aircraft or you make to
much load to and is not posible to charging so many time like Nic or Nim.
Best regards Peter
