No I'm attempting to put relevant data out there to show why lead-acid
batteries (no matter how their plates are designed) won't ever deliver
power for less than about $1 per kWh.
You compared state of the art deep cycle sodium sulfur batteries
against car cranking batteries used as deep cycle batteries and you
don't see this as misleading?
Discharged 60% each day. That's cool. That suggests they're
super-batteries of some sort!
....<snip flood of irrelevant questions>...
It suggests that they are the proper battery for the job and that
ordinary deep cycle batteries last longer than 200 cycles.
But remember, they only last 200 days at 80% discharge recharge.
Typically. Even 'state of the art' batteries. The physics doesn't
change that much between cranking batteries and deep discharge
batteries.
I don't know about the physics but I do know that deep discharge
batteries are built very differently than car batteries.
So, for a $90 lead-acid battery like the T-105 with a capacity of 0.9
kWh being used to only 20% of its capacity, means that it stores and
retrieves 0.18 kWh each day. Multiply that by 1500 days and you have a
total amount of power 'handled' by the battery of; 270 kWh. That's
$0.33 per kWh for direct battery costs alone! With replacement every 5
years or so.
Hmm, he claimed 40% discharge, not 20%. So, assuming your other numbers
were correct, that would be $0.16 per kWh.
Now, it's not my job to do your homework for you but I was curious
enough to see just what good deep cycle batteries are like.
It's a bit of a long link, and might wrap, but I found this website.
http://store.altenergystore.com/Bat...-4-Ks-25Ps-4V-1350Ah-20Hr-Flood-L-Acid/p1640/
They sell the 4-KS-25-PS for $852.53 with free shipping on large orders.
It's a 4V battery with a 20 Hour capacity around 1350 for a total
capacity of about 5400 Watt-hours. It's warrantied for 10 years with
the first 3 years free replacement. The graphs on the webpage, while
very general, seem to indicate that at 50% depth of discharge it will
last at least 3000 cycles and at even 80% discharge it'll last nearly
2000 cycles. It seems even if you abuse it and discharge to 100% it'll
still outlast the 3 year free replacement terms.
Let's assume 50% dod or 2.7 kWh a cycle. Over 3000 cycles this would
amount to 8100 kWh. $852.53 / 8100 = $.105 (approximately).
That's nearly $0.10 per kWh for direct battery costs alone! With
replacement every 8 years or so. Of course, if you replace it under
10 years you get some of your money back (pro-rated).
Anthony
