Hello
I have a circuit with a BC857B where the transister gets destroyed.
I am a litle out of ideas. When mounted on the board i have seen
arround 150 transistors out of 1800units where destroyed.
The transistor in first place seems shorted between collector and
emitter, the ressistance is between 5 to 250 Ohm.
The funny part is both "diodes" in the transistor can be measured
from
base. And the one with 250Ohm i have tried to activete in the circuit
and the transistor seems to react and make lower ressistance between
collector emitter. (so in fact it looks like a normal working
transistor with a build in ressitor of 5-250ohm between collector and
emitter)
The product has been produced for several years with out problems,
they started in earlier this year..
I have got several transistors decapped, so there seems not to be any
burned inside the transistor and the boundings where ok. I have only
seen the chip from the top, and collector emitter is in top of each
other.
The product is assambled by proofesinel production house and been
both
reflow and wave soldered
(only wave soldered on the bottom side)
Another funny things are there are 2 of the same transistor on the
board, we are only seeing one of them with error so far.
I have measred the currents in the circuit it seems ok.
There has been tried to change transistor vendor, and there has been
seen the same problem, but only 25 of 1800 with same error.
Does anyone have a auggestion to the error, or seen similar ??
Best Regards
Rapzak
from
emitter)
other.
both
Best Regards
Rapzak
