Sean said:
If anyone's got any ideas (schematics), for a 12V Lead acid battery cut-off
circuit (10,5V - so I've heard). The equipment draws approx.100ma.
I've seen a circuit which runs a transistor in series with the load ??? I
just can't seem to locate it. What ever the circuit, I think its going to
require some hystersis .... maybe I can drive the base of a series
transistor with an op-amp (Voltage comparator) .... Just let me know if I'm
dreaming.
1. Download and install LTspice/SwitcherCAD III from
http://www.linear.com/software/
2. Cut and paste everthing below the ____________ in this message
into a text file named "DisCon.asc".
3. Start up LTSpice
4. File/Open DisCon.asc (from where-ever you saved it)
5. Click on the LittleRunningMan button.
6. Select V(Load) for plotting. It shows the Load voltage vs time as
the simulated V(Bat) goes from 13V to 9V. (You can add V(Bat) to
the plot pane by clicking on the wire labelled "Bat".)
This circuit does a good job of disconnecting the load when V(bat)reaches
the set point controlled by R5. The voltage drop across the PFet is only
a few mV while the load is on. The Battery current after the load is
disconnected is <1uA.
What I didn't work out for you was an automatic start up circuit when a
charger is connected to the battery. I'll leave that as an exercise to
the student
Prof. Mike M
_____________________________________________________________________________________
Version 4
SHEET 1 880 680
WIRE 80 -80 128 -80
WIRE 352 64 352 32
WIRE -192 64 -192 32
WIRE 0 48 0 -32
WIRE 208 304 208 240
WIRE 128 304 128 272
WIRE 0 64 0 48
WIRE 64 112 208 112
WIRE 128 -80 208 -80
WIRE 128 -32 128 -80
WIRE 128 48 128 176
WIRE 128 176 0 176
WIRE 0 176 0 160
WIRE 208 -32 208 -80
WIRE 208 -80 352 -80
WIRE 208 112 208 48
WIRE 208 160 208 112
WIRE 352 -80 352 -48
WIRE 128 208 128 176
WIRE -64 -48 -64 -80
WIRE -64 -80 -16 -80
WIRE -64 32 -64 48
WIRE -64 48 0 48
WIRE -192 -48 -192 -80
WIRE -192 -80 -64 -80
FLAG -192 64 0
FLAG 352 64 0
FLAG 208 304 0
FLAG 128 304 0
FLAG 352 -80 Load
FLAG -192 -80 Bat
FLAG 128 176 z
SYMBOL pmos 80 -32 M270
SYMATTR InstName M1
SYMATTR Value IRF7406
SYMBOL res 336 -64 R0
SYMATTR InstName R1
SYMATTR Value 100
SYMBOL Misc\\battery -192 -64 M0
WINDOW 3 -93 172 Left 0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName V1
SYMATTR Value PWL(0 13 10 9)
SYMBOL res -48 -64 M0
SYMATTR InstName R2
SYMATTR Value 100k
SYMBOL res 192 -48 R0
SYMATTR InstName R4
SYMATTR Value 100k
SYMBOL res 192 144 R0
SYMATTR InstName R5
SYMATTR Value {Var}
SYMATTR SpiceLine tol=1 pwr=0.1
SYMBOL npn 64 64 M0
SYMATTR InstName Q1
SYMATTR Value 2N3904
SYMBOL zener 144 272 R180
WINDOW 0 24 72 Left 0
WINDOW 3 24 0 Left 0
SYMATTR InstName D2
SYMATTR Value 1N750
SYMATTR Description Diode
SYMATTR Type diode
SYMBOL res 144 -48 M0
SYMATTR InstName R3
SYMATTR Value 4.7K
TEXT 260 282 Left 0 !.tran 10
TEXT 136 -152 Left 0 !.NODESET V(Load)=13
TEXT -256 288 Left 0 ;Voltage dependant \nLoad Disconnect\nMike M\n4/8/2004
TEXT 8 344 Left 0 !.STEP param Var 82K 100K 2K
TEXT 16 376 Left 0 ;R5 (80K to 100K) adjusts trip point
