E
Eugene Varnavsky
I've got a "Fast" Uniross charger and two AA-sized Uniross Ni-MH 2000 mAh
accumulators.
This charger, as documented, gives 250 mAh for AA batteries for 5 hours, and
then turns to trickle mode.
I measured the current, and it's only 150, not 250!
Anyway, this charger seems to be inappropriate for 2000 mAh accums, because
250 for 5 hours means 1250, instead of required 2000.
Can i use it to charge 2000 mAh accums? Will it damage them if they will be
used not completely charged?
Is there a way to tweak this charger for higher current or longer time?
And, at last, why it gives 150 mAh, not 250 as documented?
P.S.
Charged accums give 1.38 volts, and trickle mode is 15 mAh.
accumulators.
P.S.
