Hey all --
I'm trying to build a battery box knowing just enough to be dangerous. Hopefully the attached picture/diagram gets my plan across.
There are probably things I'm not even aware I'm not considering, but my main question is: when charging the battery via the Anderson connector, will the current flow only to the battery (path of least resistance?) or am I potentially sending current through the 16 gauge wire and lighting up the USB adapter/fuse as well?
