rickman
The AT91SAM9261 uses 1.2 volts on the backup voltage for the RTC. It
only needs 2.5 mA, so it will run nicely from nearly any battery. But
to use a primary cell requires some sort of regulator to reduce the
voltage. Anyone have any suggestions on how to do this without
increasing the battery drain enormously? All the off the shelf LDOs
have quiessent currents of 10x and higher.
I just bugs me tha they designed an RTC that you can't just connect to
a battery. Couldn't they have made it work with a 3 volt lithium
battery like all the other RTC circuits???
