Hi guys,
I have a new project im undertaking whereas i need to drive a string of RGB LED flex on a battery pack.
ideally I would like the battery pack to be a custom made long cylindrical one, circa the same size a a "d" size cell but can be up to 1m long if needed.
I need the LED flex to run worst case scenario onto full white for approx 6-8 hrs. my supplier has x 2 different types of LED flex that can either run at 36w/m or 72w/m.
ideally I need to run x4m of flex at once. all the control side im happy with its just batteries are a new area that i have yet to explore and there seems to be so many options.
so questions are as follow.
many thanks in advance
Mike
- what minimum AH will i require
- what type of battery will best suit my needs.
- can this be mad from off the shelf cells joined together or does anybody have any ideas as what would be the best option..
- would i gain any advantage by running the 24v LED flex as opposed to 12v
Mike
