Platforms
Content
Not necessarily. But it does take more energy.
Moha, the more energy you push into the battery the more heat produced, the heat produced is simply wasted energy, so slower the charge the better and the battery will last longer as a result.
eg, if a battery is (1.2v 1000mah ) (with exception to the tapering off near full charge) if completely drained, you can calculate how long you need to charge it for...
eg, if you deliver a constant voltage/ constant current.. 100ma/1000 = 10 hours to fully charge) but, if you put in 1000ma you'd have it charged in 1 hour and so on.
but.... If most intelligent chargers, will pulse charge, eg 1000ma for 2/3 seconds then it stops charging, measures the voltage (if it's at 1.5v stop, if it's less than 1.5v keep charging) etc, 4.25 for lithium, different values for different battery types..... ni-cad, lithium-ion, li-poly, nimh, and all the rest... so it purely depends on what the battery is and what it was designed for..
bottom line... if you over charge, or put too much current through, the thing will if you're lucky just explode.... lithium if you're lucky will only burn 1 room down
Wow thanks for that advice! Really appreciate it now i can avoid hurting my self and causing damages in my room!
But on thing. If I draw for example 1.2V at 2.5Amps how long would you think the battery will last?
And since i can't give the battery more energy for safety reasons I'll charge it with the exact same amount of current so if I used it for 10 HOURS I'll recharge it for 10 HOURS?
So it's balanced right?
keeping with the 1.2v/1000mAh drawing 2.5 amps will drain the battery completely (under perfect conditions) in 24 minutes (60mins/2.5)
you can charge a battery with more current than is drawn from it, you just have to be careful with it, again with the example 1.2V/1000mAh drawing at 100mA will yield a 10 hour discharge, you can safely charge it at 1000mA (1A) and it will be charged in 1 hour
a general rule of thumb is the rated c-rate (as it is called... 1000mAh) is what you can safely charge it at, though with most cells you can double that rate, and sometimes all the way up to 10 times that rate, though it is recommended to stay close to the noted c-rate.
The battery is rated at 1.2V 2500mAh. I'll draw about 1.2V and 2500mAh and then recharge it with 1.2 and 3amps.
And btw im building a charging unit with its own circuit the power is about 30W and im afraid im giving the battery more power than it needs.
30/1.2V = 25Amps and that a lot to give...Im worried that i would supply much more power to the batteries what should i do in this case?
Yea I knew that for a fact but if I use a battery for like 10 mins. then recharge it with a little more power you think it recharges in 10 mins? How can I calculate this process perfectly?
And if i recharged the battery with less power would it take longer to recharge?
It take longer to charge.
Discharging at 2.5A will discharge the battery in under an hour. You also won't get 1.2V all the time, so specifying the voltage at which you are discharging is pointless.
Charging at 3A will charge it in about an hour.
I hope you know when to terminate the charge because if you don't you may damage the cell.
edit: the current is limited by the charge on the batter and its internal resistance. Unless you're doing something really silly (or amazingly well optimised) you won't get anything near that current.
How do you detect end of charge? If you''re rapid charging a cell (which, incidentally often does not fully charge the cell) then you need to be very careful about overcharging.
So the charging and the discharging is not equally balanced? Even if i discharge it at the same rate as recharging it?
I'm sure there was a post in this thread where you were told that you need to put more energy into a battery to recharge it than you take out when you discharge it.
You charge a battery until it is charged, then you stop. And depending on the battery type, the rate at which you charge it may alter one or more times during the process.
A battery is not a capacitor. And even if it were, there are still losses.
If possibile someone could right down some laws or anything that i can lean to when I'm working on charing and discharging... with more details if possibile.
Thanks!
