Basic project: Want to build a basic power supply with variable voltage/amp output
Chris
I am new to electronics, and I love to play/learn via hands on
experience.
What I would like to do, is built a home brew power supply with
variable output. Eg. A power supply that I can set to output
anywhere from 1.5 v to 120 volts for common household items. For
instance... lets say I have a hand held driller that requires 4
batteries ( 1.5 volts 1AA battries ), I would like to connect the
driller to my home brew power supply to get its electricty and power
the device.
Is this possible? If so, has anyone done it? I know you can probably
purchase one, but I would like to attempt at least at making one if
the costs are not high. I have many spare parts from vcrs power
supply, etcs..
Thanks to everyone for your inputs
Thomas C. Sefranek
Chris said:
I am new to electronics, and I love to play/learn via hands on experience.
The range is probably excessive.
Do yu really need 120 volts DC?
A more realistic range might be 1.2 to 30 volts.
For
the device.
Many times.... more than I care to admit....
supply, etcs..
You should start with what you have for a step down transformer.
(Voltage and current ratings...)
E-mail me, if you want more advice.
| __O Thomas C. Sefranek [email protected]
|_-\<,_ Amateur Radio Operator: WA1RHP
(*)/ (*) Bicycle mobile on 145.41, 448.625 MHz
http://hamradio.cmcorp.com/inventory/Inventory.html
http://www.harvardrepeater.org
