Can someone tell me what an oscilloscope is in plain English? For
example is an oscilloscope simply is a device that takes a sampling of
the changing voltage/current over a small time frame like 1 millisecond
and plots it on a graph. Usually the resulting graph is a sine wave
which is AC current.
Correct?
Think of an o'scope as just being a voltmeter that can respond to
changes in voltage really, really quickly.
Instead of using the measured voltage to deflect a moving needle, as an
analogue voltmeter would do, the deflection is applied to coils that
steers an electron beam. That's what makes it fast; it's only moving
tiny electrons and not the mass of a needle. For the sake of argument,
say that the coils move the beam UP for a positive voltage, and DOWN for
a negative one.
Now, if one simultaneously deflects that electron beam left to right
across a phosphorescent screen, the resulting glow will paint a picture
of how voltage is changing with respect to time.
That's really all an analogue o'scope is. You'll be able to change the
vertical (voltage) sensitivity to look at signals of different voltage
ranges and vary how quickly the beam is swept across the screen to see
quickly or slowly changing signals.
The "trigger" just says: Wait until a voltage that I set is seen before
starting the sweep (time) across the screen. That helps a lot in looking
at repeating waveforms or starting at a desired spot in a wave train.
Digital o'scopes sample the voltage and display dots on the screen
instead of steering an electron beam but the behavior, for the most
part, mimics analogue scopes: vertical = voltage, horizontal = time.
To complicate matters, many scopes allow one voltage channel to be
applied to the Y-axis (vertical) and a second to the X-axis
(horizontal). This is "X-Y" mode (clever, eh?).
