Charlie E.
Hi All,
Just posing a little question on the design of photodiode amplifiers.
It is interesting how, so often, when you look into doing something
you haven't done before, you run into interesting bits of 'common
knowledge' that you don't know, and have a hard time finding!
In this case, I am designing a simple color sensor. I originally was
going to cook book it with a pre-made sensor IC that I2C communicated,
but ran into two months of programming difficulties, non-documented
features and bugs, and have finally decided to 'simplify' things, and
just roll my own.
Now, National has Sensor Webench, that will basically let you take a
sensor, and they will build the amplifiers you need for you.
Interesting, but you don't LEARN anything. Also, if you need a sensor
not on their 'list,' you are pretty muich SOL. I need a visible light
photodiode, and I didn't find one that I liked on their list.
So, I decided to try rolling my own, and looking at both their
examples, and in AoE, I see one interesting thing - a negative bias on
the photodiode. So, my first question - how is this negative bias
usually generated? And at what voltage? It is just 'assumed' that
you know these things already! I am trying to build a very portable
device, and wanted to use a single 3.3V supply for everything.
Thanks for any advice and good sources for more research.
Charlie
just roll my own.
Charlie
