Hi guys,
I have a DMX splitter with a faulty output. This unit is used to split the signal from a DMX lighting console into 4 optically isolated outputs but one of the outputs is faulty. When the splitter receives DMX signal from a console, the green LED's at each output light, signalling proper output. The red LED's also light, whether or not the unit receives a signal. The green LED on the faulty output in question remains lit, whether or not the unit is receiving signal and the red LED does not light at all. So far I've checked voltages at each of the 120VAC/8VAC transformers and I'm getting 10VAC at each transformer, except for the one feeding the faulty output, 8VAC off this transformer. The voltage seems fine, within the range I would think, but I've noticed a slight swelling on the left side of this transformer. I also checked the voltages at all the LM7805 voltage regulators and the 12VDC side on the 7805 that feeds this output comes in at 8.7VDC, all the others are between 9.75 ~ 11.75VDC. Any ideas as to what I should check?
