Platforms
Content
they will symmetrically clip a signal appearing across them to the approx. voltage of the diodes (6.8V)
so if there is an AC signal coming out of that Op-Amp, through R133. the resulting output past the diodes towards R132 will be a rough looking square wave
Even a comparator can output an AC signal. AC is not limited to sinusoidal signal. AC means Alternating Current and encompasses any waveform that is not DC. A square wave from a comparator is AC, too. The zener diodes limit the amplitude of the signal to approx. +-7.5V whereas the output from U27 can be much higher, depending on the power supply +V and -V.I was thinking that also but, isn't U27 a comparator?
So U27 is not outputting an AC waveform i'm thinking
I think that's what I wroteThe maximum voltage appearing across them will be 6.8v + 0.7v = 7.5v in either direction
they are the same
So they can have the same RC values? so how can you tell which is which? if you don't know what the input waveform is either AC or DC
How would a tech know by looking at a schematic
I found another back to back zener diode on the op amps input pin
These diodes must clamp or clip the waveform symmetrically
