Bachelor combining electronics, computer and communication?
O
oopere
Today many systems integrate knowledge from these three fields.
However, most bachelors are focused on a subset of them. Are you aware
of any degrees which give a broad view of these fields?
I have been able to find very few, and it is not easy to search for this
as this requires digging quite deep in the specific programmes. The most
similar to what I am looking for is the Bachelor of Sciences in Computer
Science and Communications Engineering of Duisburg University.
http://www.uni-duisburg-essen.de/studienangebote/studienangebote_07116.shtml
I would appreciate any information on similar degrees in (worldwide)
universities.
Pere
O
oopere
John said:
Tulane University, in the wake of Hurricane Katrina, did a lot of
soul-searching. They decided that they didn't have the critical mass
or resources to run an excellent engineering program, and President
Cowan decided to dump it. The dean of the engineering, Nick Altiero,
would have none of it. So he invented a 5-year dual-major program,
things like physics+EE, or biology+ME, with the hard engineering
component done in the last year or two at another school, like Georgia
Tech. Nick runs the whole thing now.
John
We are currently developing a new integrated engineering degree
combining the areas of electronics, computers and communication with
more or less the same emphasis on all of them. A lot of systems today
require engineers that know as much as possible from:
-analog (including power and RF) and digital circuit design
-programmable devices (CPLDs, FPGAs, "PICs", "AVRs" ...)
-high and low level programming (+ the associated tools: versioning..)
-signals and systems theory
-analog and digital signal processing
-computer networking
Finally, they should be able to integrate this knowledge in a system
that works (from powering the devices to relevant standards, from
specifications to budget, planning, teamworking...).
But it seems there are not many universities offering such an integrated
engineering program, which is kind of a surprise.
Pere
O
oopere
Joel said:
It might be because you have such a wide range of topics there that the
knowledge you can impart in 4 or 5 years is probably going to be pretty
shallow. It's one thing to say, "oh, I want some guy who can design a
board using a SimpleSwitcher and some 'bits in, RF out' IC and hook it
up via Ethernet and write some C++ code using a provided TCP/IP stack to
build a wireless link," but it's quite another to expect that you'll be
able to find many single people who can do all of, e.g., "this guy did
the custom magnetics design for the switcher, made sure it passed
EMI/EMC limits, designed some mixers and RF amplifiers starting with
transistors, wrote all the DSP code from scratch to implement our fancy
new custom modulation scheme, and then wrote an optimized TCP/IP stack
to achieve the best throughput possible all at very low power and making
for a very low priced board when it's all said and done."
You are absolutely right. If you want it broad, it can't be too deep.
But, as you point out, there is demand for this kind of engineers.
Granted, there's certainly demand for "very broad but not too deep"
engineers out there (isn't that largely what industrial engineers do?),
but you can bet that a lot of the professors are going to be somewhat
reluctant to take what they consider to be a very "thorough" course and
make it more of a "survey" course to meet your objective.
For such an approach to be successful you have to redesign each course.
And, most notably, you have to present each subject as part of a whole.
This is in contrast with most "traditional" degrees where each subject
is an island with almost no connection to anything else. And this
requires a substantial effort from the teaching staff... We'll see how
it works!
Pere
JosephKK
Pere
Not a surprise at all, universities tend to spit out what industry says
it needs, and not just in engineering. That is a major reason for the
properties of new graduates for at least the past twenty years.
The people you really want will achieve the cross fertilization on their
own, the ones who won't learn some more are the people you don't want.
