I have a B&W A7 audio system that no longer powers on. I have pulled the unit apart and inspected for damage to the Power Supply and there are no visible burn marks or anything that I can see. SMPS70_v1.1 is the part number.
However I can see that these seem to fail semi regularly.
I have tested it a little bit using my multimeter and I can see a fluctuating 5v (jumps around like 3.9-4.9V) line going from the PSU to the main PCB. I have seen that if you jump this 5v to another pin of the connector on the PSU that it should turn on the amp, but this does nothing at all. i've tested around the board and can see no obvious shorts to caps etc. But im not 100% up with how to test everything.
Any help would be greatly appreciated in regards to trying to diagnose and repair the issue.
PS. i'm slightly new at this. I've only repaired a few Laptop mainboards are this point.
I gave up trying to upload photos here, but here's a google drive link to them:
https://drive.google.com/file/d/13oT_SbxopDm4xs96cCSdk8mCatPitNQ-/view?usp=sharing https://drive.google.com/file/d/1kgr4Geg2tBNkzbN14-mWqnkPGgrYG5lD/view?usp=sharing
