I recently picked up this turntable for cheap, but the motor won't spin. I opened it up and realized that someone had already been playing with the wiring a bit, and after looking at the wiring diagram, I wasn't sure it was even connected right. The wire colors don't match what it says on the schematic, so that makes it extra confusing, but when I had finally decided I had it all figured out, the motor still doesn't spin.
Here's what it looked like when I first got it:
And here's the schematic:
Since then, the bearings have been cleaned, oiled, and I'm able to spin the rotor freely with my fingers. The resistor and capacitor both tested ok and I cleaned the contacts on the switch mechanism. Also, while I was trying to figure out how the motor wires were supposed to be connected, I did a resistance check with the wires unhooked.
Black - Blue = 327.4 Ohms
Red - Yellow = 331.6 Ohms
Every other combination showed no connection. I have no idea what the resistance is supposed to be, but I figure the electricity has to go somewhere. So, I decided that the Green wire that is mentioned in the schematic must actually be Black, and the Brown one is Red.
Here's what I came up with:
This may provide more information as it shows how the wires connect to the motor:
So far, no combination has gotten anything more than a hum from the motor. Is there a quick test to show whether or not the motor is good? Any information would be helpful at this point
