AVR, external clock
U
Umpa
Hello,
I have got AVR ATmega16.
I`m developing an application
which should receive data from
UART.
I would like to conntec external
oscilator of 11059200 Hz.
I connected it to XTAL and set
fuse "ext. clock", but processor
doesn`t work.
What to do to make my processor
working with external oscilator
and using it for UART?
Umpa.
Anders
What type of XTAL is it ?
What input pins are you using ?
/Anders
Anders
OK
Have you connected 2 capacitors to the XTAL ?
22-33pF is mostly used, look in the datasheet.
/ Anders
U
Umpa
Yes. Two capacitors of 27pF connected to XTAL1
and XTAL2 and GND.
Test:
I connected 8MHz oscilator, set fuse XTAL3-8MHz.
It works.
I connected 11MHz oscilator, set fuse XTAL3-8MHz.
Doesn`t work.
I connected 11MHz oscilator, set fuse XTAL3-8MHz,
changed state of !CKOPT.
Doesn`t work
I tried a few 11MHz oscilators.
If I use oscilator slower than 8MHz there are fuses that
cover it (XTAL3-8, XTAL...)
But my oscilator is 11MHz. Atmel`s manual says that
we should change CKOPT for oscilators faster than 8MHz.
But it doesn`t help.
Umpa.
U
Umpa
Is it at MEGA16 or a MEGA16L ?
I have got ATmega16. Without "L".
Any idea about my problem ?
Umpa.
