Automobile battery charging
Tim Shoppa
Is it possible to charge a car battery using the
cigar/cigarette outlet. If so, what would the
maximum charging rate be?.
Usually the car has a 15A fuse on the cigarette lighter circuit. If
you buy a pre-wired lighter "plug" or hack one of an existing device
(e.g. laptop charger or cellphone power) the true current limit is
probably the skimpy wiring attached to the plug (maybe a few amps!) At
least some of these plugs have integral non-replaceable fuses at a few
amps, and some have solid-state circuitry built into the plug which
will get in your way!
Tim.
Dave Platt
Is it possible to charge a car battery using the cigar/cigarette
outlet. If so, what would the maximum charging rate be?.
In most cars, it is possible - the cigar/cigarette/aux-power outlet
usually has a fairly direct feed to the battery, often through a fuse
of its own.
The max charging rate would depend on the vehicle. You'd need to
check the fusebox and/or the owner's manual, and find out what sort of
amperage fuse is used for this feed and whether the owner's manual
says anything about the safety of doing high-current transfers through
this outlet.
The contacts in these outlets are sometimes quite rugged and robust,
and are sometimes pretty wimpy - the latter in cases where the outlet
is intended as a low-amperage auxiliary supply for laptop PCs and tape
players, and not as an actual cigarette lighter.
Trickle and float charging, at rates of up to a couple of amperes, is
probably going to be safe. There are some solar chargers, intended to
provide a low-level float charge for vehicles in storage, which work
this way. I believe that there are some line-powered chargers, good
for a couple of amps, which are used to recharge or float batteries in
cold climates to make sure that they're in good shape to start the car
when the morning temperature drops below zero.
I would not stick a cigarette-lighter connector on the wires from a
stand-alone fast-charger and plug it in... a continuous flow of 20-30
amps is probably quite a bit more than this outlet ought to be asked
to handle.
Jim Adney
The allowable charging current would be somewhere between 5 & 15 A,
depending on the wiring in the car and your adapter.
On many cars, thie outlet is disconnect from the battery if the key is
OFF. You could switch it to ACC, but this might turn on more things
and draw more current than you were able to pump into the system,
which would make this a losing proposition.
I once modified a car just so I could do this. I had to reconnect the
lighter jack to a fuse that was hot all the time.
