Hey guys I'm a Mechanical Engineering Senior working on a Senior Design project. Our project is to redesign a testing apparatus for a positive pulse mud telemetry tool. How the tool operates isn't really important to our project (if you're curious I'll explain it), but what is important is the measurements they want our test apparatus to be able to take. The project is a redesign of a current testing apparatus, the apparatus is operated manually by a technician and they want to automate it so that the tech just pushes a button on a computer and the device reads several measurements on it's own without prompting. So far we can automate, the RPM, Temperature, and stroke length measurements. We just have a question regarding the resistance measurements. The tool in use is below surface and is controlled above ground by an operator, the signals our sent to the tool through a wire, which sends signals to open/close a valve. The wire is composed of 6 different segments all bundled together they want to check the resistances between the wire while it's hot and again while it's cold. Righ now the tech performs this using a multimeter checking a-b a-c...etc. Again they want to automate this so the computer sends reads all these a-b signals without requiring the lab tech to touch wire to wire manually. My question is if we design a cap of sorts that allows a multimeter to be plugged into all 5 wires at once is there a way to filter the voltage sent by the multimeter to just two of the leads and then to another two so that it is essentially doing the A-B, A-C measurements automatically? If you guys could help I would appreciate it, my circuitry knowledge is limited at best.
-Josh
-Josh
