Hello,
I’m currently trying to create an automatic system to either open or close the door/window of a greenhouse dependent on the internal temperature. For example, if the actual internal temperature is lower than the set point, the window will close a set distance dependent on the temperature variation between the ideal and actual temp values.
The problem I am facing now is what kind of system to build to address this. The solutions I think could be used are:
· PID temperature controller
· Arduino, and code the system, with inputs of a set point and temp sensor
I will then 3D print a rack and pinion to attach to a motor that is driven by either the PID or Arduino system.
If anyone has any suggestions as to which would be the best system to pursue, or a whole new idea entirely I would be keen to hear them. Thank you for taking the time to read this and I would be very grateful for any feedback or help.
Many thanks
Many thanks
