Looking for recommendations for an off the shelf programmable auto resetting timer for an appliance. eg. set for 10 minutes, once the well pump starts it will run for a max of 10 minutes and then be turned off. If the pump turns itself off before the preset time the timer resets to allow another max 10 minute run. the purpose is if the plumbing springs a leak the maximum flood time is 10 minutes. (should the pump re=un 10 minutes the user would have to manually reset the timer)
Platforms
Content
