Jon Noring
A crazy and, more likely than not, stupid idea (and which no doubt has
crossed the minds of others) hit me as I thought about amplifying weak
audio and RF/audio signals. The usual technologies for amplification
include tubes and transistors. Why cannot lasers be used for electronic
signal amplification? (Maybe they have, but I have not yet found any
discussion/information on such devices...) Let me explain what I mean:
In triode tubes, for example, when a weak input signal is applied to
the control grid, it regulates the higher-power current flow from the
plate to anode. Amplification of the signal is achieved.
If we now visualize the laser analog to the triode, where we replace
the current flow from plate to anode with a high-power continuous
laser beam directed at a spot photocell, and replace the control grid
by something else which modulates or deflects the laser beam based on
the weak input signal, then in essence we can (at least as I see it)
potentially achieve a very high gain of the input signal, and, if
properly and cleverly designed, may also achieve quite linear, low
distortion, low-noise response. It may open up new possibilities for
high-end audio components (amps, phono-amps, radio tuners, etc.) and
for various scientific applications where space/weight is not a
critical factor.
For example, in the simplest "mechanical" analog of this system,
imagine a higher-power laser beam directed at a photocell via a small
reflecting mirror. By applying to the mirror the weak input signal so
as to somehow deflect it a tiny bit, we can effect quite large
deviations of the reflected laser beam directed at the photocell
target. The photocell would then output a much higher powered signal
modulated by the weak input signal.
There may also be "non-mechanical" ways to modulate/deflect the laser
beam, but I do not have any concrete ideas regarding those.
So, is there a fundamental problem with this idea? (Of course, there's
lots of real world issues, such as vibration and inertia issues for
mechanical type of modulation, and various inherent sources of noise.)
Has anyone done research and development in this area, possibly even
marketing a product which accomplishes pretty much as described above?
As my graduate advisor once told me: "A person can think of a thousand
reasons why something won't work, but all you have to do is think of
ONE way to make it work."
I look forward your thoughts and, of course, criticisms on this nutty
idea.
Jon Noring
critical factor.
idea.
Jon Noring
