Platforms
Content
What kind of noise 50/60 Hz hum?
Bob
It is probably not the amp itself, it is probably there on the input. You only didn't hear it before because of the bass cut. What is the input?
Bob
Hi duke37,You have not said what R1 is for.
You have not said what gain you want.
You have not said what the source impedance is.
You have not said what the load impedance is.
I attach a diagram of a two transistor circuit which will have a high input impedance and a fairly low output impedance. The gain of the basic circuit will be 1+R1/R2.. The resistors affect the DC operating point so the gain is probably limited to 5.
The gain can be increased by placing R3 across R2 with a capacitor in series to stop DC current.
You could spend many happy hours on a simulator with different components and impedances.
For 50Hz hum, try shorting the input and see if it disapears. If it stays, it is probably the power supply.
I have not given values of components since the requirements were not given.
Perhaps TINA is reliable, I can assure you that strange results can be obtained in practice!
If your existing circuit is working just use it.
Getting rid of hum can be very difficult. All power supplies should be smoothed properly and all leads should be short and perhaps screened.
One way of getting hum is if there is an earth loop which picks up a magnetic signal from the mains. The way of getting round this is to have one common earth point for the system.
