I have an internet radio who's volume gets annoyingly loud during some commercials and I am trying to figure out a simple way to automatically reduce that volume. The output of the radio goes to an amplifier via a standard headphone jack on the radio. So inserting a limiter of some kind in that output wiring is easy.
I've tried clamping the audio line with back to back silicon diodes and that does help, but it's still too loud. I'm still playing with this technique and may try germanium diodes, etc. I don't think I need much help with this technique. BTW, I mostly listen to talk radio and the P-P voltage is about 1.2v at normal listening levels. With talk the signal looks like lot of spikes with lots of dead intervals.
Anyway, I was thinking of another technique that doesn't need a power supply. I'm thinking of rectifying and filtering the audio voltage and using that voltage to somehow control the audio feed to the amp. For example, there may be enough power to activate a sensitive relay that inserts a resistor divider circuit into the audio line. Or maybe there's an led/ldr optocoupler that might work, although, I'm not sure there would be enough power to activate the led.
So If anybody here has some other ideas or suggestions on the above.I would love to hear them.
Thanks, Frank
Thanks, Frank
